VFR400 big bang theory ?
johnnie5
Post by johnnie5 »
while driving around today go to thinking
VFR400 sounds nice and smooth
VFR800 has that nice deep throaty rumble
anyone thought about swapping the cams in 1 head 180 degrees , since bikes run a waste spark it should still run , but how would it perform ?
any performance difference? , sound different ?
Re: VFR400 big bang theory ?
I don't think it would work. Just don't see it being that easy..and what would you want to change anyways? The 400 or the 800?
Cammo
Post by Cammo »
johnnie5 wrote: anyone thought about swapping the cams in 1 head 180 degrees , since bikes run a waste spark it should still run , but how would it perform ?
That just aint gonna work Johnny!
johnnie5
Post by johnnie5 »
CMSMJ1 wrote:I don't think it would work. Just don't see it being that easy..and what would you want to change anyways? The 400 or the 800?
for the 400
i can see now by the diagram how it fires so it wouldnt make a whole load of difference
by changing the cams instead of opposing cylinders firing they will fire 1 side and then the other , the question is would this change how the bike feels
Jon
Post by Jon »
The crankshafts are different in the the 180-180 firing versus the 90-270 firing.
The VFR800 is the same configuration as the NC24 with a 180 degree crank and even firing rather than the big bang style of the NC30 (OK so its not that big a bang).
regards
jon
Honda NC30
Ducati 900 S2 (under constrcution)
Moto Guzzi Le Mans III
Honda CB550F2
BMW R90S
