Carb Help
Carb Help
Hey all,
I took my carbs off a while ago and now I am back to put them on I have no idea where the pipes all go to inc the vac pipe?? ANy help would be great.
Also I am about the balance them any ideas on the size if the adapters to attach the balancers to them and last of all how on earth do you turn the balancer screws that are on the bottom of the carbs!?!?!
Thanks for all your help
- Bike owned: zx9r c1
Re: Carb Help
im guessing you don't have a manual........
that would be the first thing i would do,buy one!!!!
william
william
Re: Carb Help
Got one but it doesnot show all the pipe connections?
- hannakournikova
Re: Carb Help
take a pic and we can stick labels on it for u
- oliherst
Re: Carb Help
You aren't going to be able to balance them on the bike without a bevel 90 degree pilot screwdriver from http://www.carbtune.com" onclick="window.open(this.href);return false;. Best tool I ever bought, excellent quality.
- RickOliver
Re: Carb Help
Which manual have you got, JP? The factory version (only £10 and I`ve got them in stock) has routing diagrams for pretty much every wire, cable and hose on the bike...
Rick
Rick
Re: Carb Help
Money Sent.
Thanks for all your help I will try that.
I assume that it can't be done without the expensive 90 degree screwdriver??
Thanks once again.
Thanks once again.
- Bike owned: '30
Re: Carb Help
it seems people who havnt much experience with working on bikes are understandibly intimidated and easily defrauded, i mean come on pay X pound for a 90' screwdriver wtf, just bend an old one and saw its handle short! your gona burn your hands on the water pipe conduit inbetween the v's, put a dishcloth over it, and youl need to balance from #2 cylinder's screw because all the springs from the other linkage seats are actuated from this one.. just play around with the screw depths until they all correct, and only balance once bike at operating temp with choke off
Re: Carb Help
Thanks for the help.It is all much appreciated.
It's not so much lack of experience it is all about a new bike and getting each others knowledge.
Thanks anyway
Thanks anyway
