Foot operated gear selector lever bushing
Sunnyday
- Bike owned: UK NC30 17" Rear.
Hi guys,
I have a little play in the foot operated gear selector lever on the hanger and would like it bang on if I could, all of the ball joints are all a ok, its just the lever movement on its shaft there is wear on it is there a copper bush in there I could replace I could not see one when I looked but I have not taken it apart to investigate.
Regards,
Regards,
kagari15
- Bike owned: FZR400 3EN1
Re: Foot operated gear selector lever bushing
A bit of play is normal. However, if it flops like you can't shift smoothly or easily that would be a problem. You can start by checking free play on the joints, foot lever and finally the shift shaft.
If it is the shift shaft that wiggles around, I think you're onto the copper bush you said. Check if the bush is worn though, to be sure.
cbr400rrn
- Bike owned: NC29 CBR600F
There is a thin aluminium washer that is used as a Bush, i replaced mine and noticed no difference (nc29.) Could you look at the microfiche to see if the nc30's have anything different.
