NC30 carb needle jets
- RickOliver
Main needle jets for NC30 carbs - these tend to wear oval with time and have never been available as a spare part from either Keihin or Honda. The ones supplied in Chinese carb service kits don`t fit or work properly so I have had a batch of accurate replicas made.
Removal of the originals is fairly simple, just using a hammer and a small steel punch - fitting the new ones requires a special hollow nosed drift to avoid damaging the upper end of the jet and I will supply this with the kit - price for a set of 4 jets including the fitting tool is £38.
Rick
Rick
richyrd5
Re: NC30 carb needle jets
Excellent idea and worthy of copying....so many are fueling wrong because of this...and usually takes a long time to suss it's the needle jet ovalled!!
