1990 SP - Valve Clearances
bluesmokeracer
Post by bluesmokeracer »
Hi All,
Can anyone confirm whether the 1990 GK76A SP valve clearances differ from the non-SP models?
Thx
BSR
moforockband
Bike owned: GK73a SP CRM250 mk3
Re: 1990 SP - Valve Clearances
Post by moforockband »
I'm pretty sure (not 100%) they all use the same camshaft, and will use the same clearance. If you have to adjust any, set them on the looser side as shim under buckets usually tighten up over time.
bluesmokeracer
Many thanks
BSR
