NC30 fork strip
socket13
Bike owned: Honda SP1, BSA Golden Flash, H
NC30 fork strip
Post by socket13 »
Stripped the forks,stanchions away for rechroming , the Haynes manual says when you start the rebuild ,you insert the damper rod minus its components and fit the Allen bolt into the damper rod and tighten to specified torque, as I didn’t need to replace any of the components on the damper rod, can I just refit it complete as it came out of the fork tubes?
sa.racing
Bike owned: NC29 Race
Re: NC30 fork strip
Post by sa.racing »
I'm not really sure what it is your asking,
I'm assuming you mean when the fork tubes come back from re-chroming?
Basically you need to re install just the damper rod, leave out the spring, washers and spacer, tighten the bolt up at the bottom this then allows you to fill it with oil and set your air gap once you've don't that then you can install the spring, washers and spacer
Hope that helps
socket13
Re: NC30 fork strip
Post by socket13 »
Thanks for your answer, told me all I need to know
