gk76a tps sensor voltage setting
Nobbsie
does anyone know what the set up voltage should be at idle and full throttle from the output?
cnt seem to find the numbers anywhere.
Nobbsie
Nobbsie
moforockband
Re: gk76a tps sensor voltage setting
Not sure if anyone will ever know, but try copy the rgv250 volts, should be similar. Are you trying to diagnose a faulty one?
Nobbsie
Na trying to work out how to set it up with a new set of carbs, I guess I’ll take a look at the rgv, what have others done?
