Bottom yoke attachments on NC24
michaelpoplett
Post by michaelpoplett »
I changed the fork seals, which is perfectly straight forward, but for the life of me I can't remember how the horn/rubber and steel guard/front brake splitter go back! Presently, I've got the front brake splitter bolted to the bottom yoke, with the horn on the front of that. Where does the rubber and steel cover go? It has to be there somewhere, unless the horn goes somewhere else. A photo of someone's bottom yoke would help a lot. Cheers, Mike michael.poplett@btinternet.com
Suzuki416
Re: Bottom yoke attachments on NC24
Post by Suzuki416 »
michaelpoplett
Thanks for this, and these charts are very useful, but none show the bottom yoke attachments as described with the rubber and steel cover! It's strange, and I'm wondering whether it's one of those things the H men did for one production run, and then ditched the idea:-/
Faxe400
Bike owned: VFR400RH, VF1000RG
Post by Faxe400 »
Hi,
can you please post a picture of your parts? I disassembled my NC24 last year and now I'm putting everything together. One was equipped with two brake lines without splitter. I will use two M6 screws to mount horn and splitter (now I have 3 brake lines) to the bottom stearing stem.
From the above link -> Stem -> Part 13 is used for my horn
Faxe400
Post by Faxe400 »
Here is a Pic from my bike.
Axel
michaelpoplett
Thank you for all the suggestions, the parts diagram, and general help. The rubber and steel guard actually bolts to the underside of the bottom yoke with a single hex bolt, and it seems to protect the aperture to the underside of the bottom yoke where you would insert the pin on a front wheel stand. MJP
