Progressive Fork Springs
maxhemacrit
Reactions:
Post by maxhemacrit » Tue Jul 23, 2019 8:00 pm
Has anybody installed progressive fork springs in an NC24?
And if so did it make any difference.
Thanks,
Keith
Reactions:
Bike owned: VFR400
Re: Progressive Fork Springs
Post by magg » Wed Jul 24, 2019 9:04 am
Why progressive, are you trying to reduce the impact harshness of the front suspension?
maxhemacrit
Reactions:
Post by maxhemacrit » Wed Jul 24, 2019 5:52 pm
No the opposite. The springs are very soft in the first part of travel.
I also think i'm getting some chatter in faster bumpier corners but I think that's a lack of 'real' rebound control.
Keith
maxhemacrit
Reactions:
Post by maxhemacrit » Wed Jul 24, 2019 9:02 pm
The only aftermarket springs I could find are Progressive.
I was hoping they would be a better spring all round compare to the 30+ year old OEM items.
Reactions:
Bike owned: VFR400
Post by magg » Thu Jul 25, 2019 1:56 am
Have you measured the unloaded and loaded sag? Where are you located? Rick Oliver on this site supplies aftermarket springs. NC24 has damper rod forks?
radarro
Reactions:
Bike owned: NC24 Rothmans
Post by radarro » Mon Sep 16, 2019 2:52 pm
Hi, late but still worth replying:
I've made general front forks rebuild early 2019. Fitted German Wirth Federn - model 5010 from link below:
https://www.wirth-federn.de/produkt/wir ... 500-s-ex5/
Reason was simple: to replace 30+ years old OEM ones and make front more stable for ~100kg rider.
I've put new fork tubes, springs, sealings and springs, and still plan to make DYI with gear list and pics to the forum...
Faxe400
Reactions:
Bike owned: VFR400RH, VF1000RG
Post by Faxe400 » Thu Sep 19, 2019 8:04 am
It's like Religion, you just have to believe ….
Original springs are progressive too.
I wanted to have longer springs, but due to unequal length of dampers and the upper metal cartridges it is very difficult. I asked at Wilbers and they sent me a sheet to measure all stuff they need (Diameter of wire, turns of spring, free length. hight of fork: unloaded, only bike itself and with me, …). Outcome for me (100kg+) was they suggested to cut 10mm off from the cartridge to make it softer.
