NC35 fuelling
NC35 fuelling
Hi,
I need your recommendation.
I'm in west London and need my NC35 setup properly in terms of fueling. I think it's running way too rich. It's making less than 100 miles on a tank full.
Is there any place or person you would recommend for this work? I guess some jetting might be required and I will need this to be done over the weekend as this is my home to work bike.
Cheers!
Cheers!
Re: NC35 fuelling
Hmm... Looks like my only option is Honda dealership...
Re: NC35 fuelling
how clean is your air filter? Simple solutions...or as you have google...look for a dynojet approved place for a run to see your fuel/air ratio
- Bike owned: zx9r c1
Re: NC35 fuelling
yeah get it on a dyno and that will show how rich it is running etc..........
how does the buke run?
if it was silly rich then i would have thought it was running like shit unless its set up to run like this!!!!!!
william
william
- Bike owned: NC29 Race
Re: NC35 fuelling
Where abouts are you mate ? there are a few places around London that are pretty good, And a few to steer clear of
When dealing with carburetors you need someone who really knows what there doing, There not hard to set-up just often misunderstood.
Re: NC35 fuelling
Not west london but i check out Southern Cross in Kilburn, they have a dyno and the guy there races an nc30, ask for Matt.
Re: NC35 fuelling
since I serviced my RVF its giving me about 20-30 miles extra on a tank... well chuffed with that.
I might go take a look see at Souther Cross too,allways good to know a desent bike mechanic.
maciekmaceik19 - Is that your RVF at Chiswick Honda?
Re: NC35 fuelling
Hi,
I'm in Northolt and yes the bike runs like shit in low revs. mpg is also ridiculously low.
I have a brand new filter and oil on the bike, carbs cleaned and synced, not sure about valves situation (might be quite bad actually)
I'll check out the Southern Cross place - hope they will be able to jet the bike properly there.
RVF007 - NO! Is there one in Chiswick honda at the moment? How nice? How much :)
Cheers guys!
Cheers guys!
Re: NC35 fuelling
Just dropped them an email. I hope the price will not make me rob houses on x-mas eve.Sam wrote:Not west london but i check out Southern Cross in Kilburn, they have a dyno and the guy there races an nc30, ask for Matt.
Re: NC35 fuelling
the RVF at Chiswick Honda is a wreck... looks like its been used to plow fields with.
check your pm.
check your pm.
