New NC30/35 Eccentric hubs - any interest...?
Posted: Fri Jan 18, 2019 9:37 am
Just putting out a feeler here -
With so many NCs having trashed rear hub eccentrics due to owner brutality and laziness (why spend £20 on the right spanner when you can wreck a £300 hub with a screwdriver and a big hammer...) and OEM replacements now discontinued, I`m thinking it might be time to start producing new ones.
What I have in mind is a hub which is machined from an alloy billet rather than a casting like the original, might with luck and cunning design be a bit lighter and which will have a more robust adjusting system - I`m thinking probably a wider flange than the original castellated rim, with radial drillings round the edge and a custom peg spanner supplied to match.
This won`t be cheap, but if I could supply the above for the same price or a bit less than the OEM part (which was £310 from Honda when last available), would anyone be interested...?
Rick
Rick
