RVF 400 rear brake return spring
nightowl11
I am attempting to install after market rear sets on my 1994 RVF 400. In order to do that I have to add a banjo bolt pressure switch and a return spring to the rear brake. Does any one know what size return spring I need for this application? Woodcraft makes springs but I am unsure what size since they don't have the RVF listed. Thanks
Sent from my SM-G930T using Tapatalk
Re: RVF 400 rear brake return spring
I'd go with a pukka HRC elastic band for now :)
And then would look to find one of the small ones that spring off the bottom of the shaft - find one adn experiment.
I use WR Battlestep pegs - and use elastic on it...I should probably find a small spring
- Tim400GB
I asked a similar question a while back and got pointed to these.
https://www.ebay.co.uk/itm/Exhaust-Clam ... 2553207622
Never actually got round to buying one and trying it but might be worth a punt
nightowl11
https://www.fasstco.com/products/rear-b ... urn-spring I am ording one of these today after I double check the sizes. I will update once It comes in.Timon wrote:I asked a similar question a while back and got pointed to these.
