RVF400/VFR400 Water Pump
ZippiT
Post by ZippiT »
Hello,
I was wondering if anyone has successfully split/gutted the water pump housing that holds the impeller/shaft?
Re: RVF400/VFR400 Water Pump
you can get a blanking plate to remove it if you are running an electric pump - is that what you mean?
ZippiT
Post by ZippiT »
Looking to remove these parts from the water pump housing
ahh - not sure I've known someone strip it that far back - mostly it is a replacement as a unit
