Carb to intake insulators / cyclinder head cover gaskets
NICKNewt
- One Hit Wonder
Hi All,
Two quick questions
1) are the carb to inlet rubbers / insulators the same for NC21, NC24 and NC30?
2) where are you guys sourcing cyclinder head cover (cam cover) gaskets? David Silver / CMS / wemoto none of them have them in stock
Two quick questions
Re: Carb to intake insulators / cyclinder head cover gaskets
nc24 / nc30 carb rubbers should be either the same part of cross compatible.
The nc21 might fit im not sure, the carbs were 30mm not 32mm but im sure its just the inner bore that was different not the outer bore so might well fit too.
