TICK OVER IS TOO FAST ?
geoff916
Bike owned: CBR 1100 XX, CBR 400 RR CBR
Post by geoff916 »
Hello all.
Just cleaned my carbs and re fitted, after several attempts at getting it started all seems fine now, carbs on carbs off carbs on carbs off lol
BUT it seems to be ticking over too fast ? there is absolutely no tension on the throttle cable and the idle adjust "knob" is not even in contact with the carb.
It sits at about 1500 rpm and wont go any lower ?
Is there another screw or something I should be adjusting ?
I did have starting issues but that was the choke "arm" not activating three of the four carbs cos some numpty had forgotten to tighten the screws up again (I was that Numpty) :oops: :oops: :oops:
Thanks guys
Geoff
Suzuki416
Re: TICK OVER IS TOO FAST ?
Post by Suzuki416 »
Balance your carbs...
ANDYC8888
Post by ANDYC8888 »
Pilot air / mixture screws would affect the idle if they're not set correctly.
northernmonkey
Post by northernmonkey »
Double check for an air leak. Spray some easy start around the carb rubbers/ inlets (not near the air intake) and see if the revs rise higher - if so then you have an air leak. Perished inlet rubbers or poorly sealed carbs can cause the same symptom. Good luck
Mark
geoff916
Post by geoff916 »
Thanks for the help guys.
I stripped the carbs again !!!
then cleaned. Re fitted. All is good!!
thanx
