3TJ top engine bolts
hardhat_harry
Post by hardhat_harry »
Anyone know the length of the M10 top frame/ engine bolts on a 3TJ? Mine are missing :(
Re: 3TJ top engine bolts
Post by Evilchicken0 »
You definitely want them :shock:
Robotnik
Bike owned: 2x3tj xs650
Post by Robotnik »
Hi
2x 40mm bolts and 2x 55mm bolts.
I think they are 10x1mm thread.
Neil
icklepob
Post by icklepob »
Does anyone know the length of the lower engine mount bolt that passes through the side stand bracket ?
Sent from my SM-G950F using Tapatalk
Robotnik
Post by Robotnik »
icklepob wrote:Does anyone know the length of the lower engine mount bolt that passes through the side stand bracket ?
I'll find out in a day or so, I've got one fitted to a rolling chassis.
I have to get the rolling chassis out the shed and remove the bolt to measure it, I'll do it when the rain stops :)
Neil
Robotnik
Post by Robotnik »
The lower bolt which goes through the sidestand mount is 185mm
The top rear engine mount bolt is 265mm and the Spacer bush which fits onto it is 57mm.
Written in text in case the pictures disappear one day :)
Neil
icklepob
Post by icklepob »
Mega,thanks for taking the time to sort this info.
Just remember those long bolts are wasted and the leg th is for the 3tj
Robotnik
Post by Robotnik »
No worries, I'm pleased to help.
Neil
