Honda rvf 400 nc35 rear Hub
SpyVFR
Post by SpyVFR »
hi, Honda rvf 400 nc35 rear Hub, is it compatible for honda nc30 ?? Please help me.
Thanks guys
RickOliver
Re: Honda rvf 400 nc35 rear Hub
Post by RickOliver »
Yes - the two are different but interchangeable.
The eccentric hub is essentially the same on both models but the axles are not.
The difference between the VFR & RVF axles is in the length and spline size of the bolt which goes through the middle of the axle and holds the rear wheel in place. Either axle will fit either bike but you do need the matching wheel bolt for whichever axle you are using.
Rick
