				3TJ fork stanchion length above rubber
				Posted: Thu Jun 01, 2017 1:20 pm
				by Maelstrom
				Hi All,
My 3TJ forks were butchered to fit some dodgy air cap things and I am just a bit worried if the stanchion was actually shortened. If anyone has the opportunity could you just measure from the top of the dust cap to the top of the stanchion, excluding cap, for me please.
Blair
				Re: 3TJ fork stanchion length above rubber
				Posted: Fri Jun 02, 2017 4:17 pm
				by chrisexup
				with forks removed from the bike the distance from the top of the dust seal to the top of the fork (without cap) is about 354.5mm
				Posted: Fri Jun 02, 2017 11:42 pm
				by Maelstrom
				Well thanks for that. Something is a bit strange though, mine is 370mm.
				Posted: Sat Jun 03, 2017 4:02 pm
				by Maelstrom
				Another 3TJ owner sent me their measurement as 356 so mine seems like someone has changed the forks and/or stanchions. Given that it has weird caps with some sort of air fitting inside.
				Posted: Fri Jul 14, 2017 7:29 pm
				by pauliealdridge69
				Xjs or r6 stanchions?
Still got standard calipers fitted? Could be the lot swapped :)
				Posted: Mon Jul 17, 2017 3:55 am
				by Maelstrom
				I only needed the correct length so that I can set my USD forks the same. The old bits can go in the bin.
