3TJ fork stanchion length above rubber
Maelstrom
- Bike owned: MC22, 3TJ1
Hi All,
My 3TJ forks were butchered to fit some dodgy air cap things and I am just a bit worried if the stanchion was actually shortened. If anyone has the opportunity could you just measure from the top of the dust cap to the top of the stanchion, excluding cap, for me please.
Blair
Blair
https://litetek.co
https://litetek.co
chrisexup
- Bike owned: fzr6003tj kr1-s d675 ypvs350
Re: 3TJ fork stanchion length above rubber
with forks removed from the bike the distance from the top of the dust seal to the top of the fork (without cap) is about 354.5mm
Maelstrom
Well thanks for that. Something is a bit strange though, mine is 370mm.
https://litetek.co
https://litetek.co
Maelstrom
Another 3TJ owner sent me their measurement as 356 so mine seems like someone has changed the forks and/or stanchions. Given that it has weird caps with some sort of air fitting inside.
https://litetek.co
https://litetek.co
- pauliealdridge69
- Bike owned: Nc30,35,998s
Xjs or r6 stanchions?
Still got standard calipers fitted? Could be the lot swapped :)
Maelstrom
I only needed the correct length so that I can set my USD forks the same. The old bits can go in the bin.
https://litetek.co
https://litetek.co
