pipes diameter
pipes diameter
What's the inside diameter of the nc21 and nc24 exhaust port and exhaust pipes?
Re: pipes diameter
is the inner diameter same as the nc30?
Re: pipes diameter
Inside diameter is 32mm 35mm od cant remermber but i think the port is 40mm or 42mm.
Re: pipes diameter
Thanks, they seems to be larger than the vf's
Re: pipes diameter
from memory they are larger an vf400 engien.ligurt wrote:Thanks, they seems to be larger than the vf's
Re: pipes diameter
vf400f i.i.d. is 27mm.
