What size flywheel pyller bolt?
MattyLawsRacing
Post by MattyLawsRacing »
What size flywheel pulling bolt do I need to get my flywheel off. I need to replace my generator behind it?
It's a 1990 fzr400rr
Thank you
Re: What size flywheel pyller bolt?
Post by Evilchicken0 »
you can use the standard bar end weight as a puller.
You'll need to heat the flywheel
enduro250
Bike owned: FZR 400 RRSP, FZR 400 RR (2)
Post by enduro250 »
3TJ /4DX: there is no need to remove the flywheel if you want to exchange the generator.
compressed air screw driver ( no idea what is the correct english name) and a short knock with the hammer and it was done for my flywheel. heating is recommended, but in my experiences, the heat is spreading to fast for the expacted effect.
It is correct standard bar end has the same thread, if I remember correct it's M18 x1,5
BR
MattyLawsRacing
Oh right it's just my generator is behind the magneto so what's best to remove that? Ps don't have a standard bar end unfort. Thank you
Do you have an American model ?
If it's not American then it's a 1wg, there are a few models within the 1wg designation - you have twin headlights, but do you have air intakes ? if so are they above or below the headlights ?
Either way I think the puller thread is the same as the 3TJ described ^^^^ above
MattyLawsRacing
single headlight bud. G reg. says manufactured 1990 and on v5 was registered 1993.
Also engine mounts are on barrel castings. all evidence leading to a 3tj1 so why isnt my genny bolted to cover instead?
MattyLawsRacing
says was registered over seas and first uk reg was 1993.
frame says.
3TJ-1117**
if that helps?
enduro250
Post by enduro250 »
to remove it, i have bought a hexagone screw M18x 1.5 len = app 150mm.
now you can use socket wrench and compressed air driver with a lot of torque.
BR
MattyLawsRacing wrote:single headlight bud. G reg. says manufactured 1990 and on v5 was registered 1993.
Odd - Maybe it had a 1WG engine with a 3tj head ???
MattyLawsRacing
I am also confused. So is it the m16 or m18?
Thank you
