NC39 VIN no. trouble
Hello,
My VIN stamped onto the rivet plate is 7AT08G0HX16044739. The 10th character is a "1" as you can see, and from what I've read this indicates the year of manufacture being 2001. Trouble is the bike was advertised as being 2003, has 'Super Four VTEC Spec II' stickers on it, as well as "Spec II" on the background of the instruments.
This has raised some red flags, especially as I remember the previous owner mentioning that the clock doesn't work and he "has no idea why". (The rubber button has nothing underneath it) - Could the whole cluster have been replaced with a Spec II cluster to make it look like it had lower k's?
My national vehicle jam report shows consistent km's since it was imported, so if did happen it was done in the country of origin - Japan.
Would just like to confirm if i'm on the right track, or if the VIN numbers are read differently for these bikes.
- royster81
Re: NC39 VIN no. trouble
Can you put up a picture of the bike please, especially the clocks.
- royster81
Ok I think you do have a spec II, fork lowers on a spec II are different than the spec I, the clocks are different also and the VTEC comes in later on the spec I.
The reason the button doesn't work could be because the little white plastic piece that goes between the rubber button and the circuit board has fallen off, this happened on mine.
Alright cheers buddy, better to know for ordering parts etc. Thanks.
- royster81
https://www.bike-parts-honda.com/moto-h ... -1172.html
On the clocks diagram part 9 is the circuit board and if you look closely, and I mean really really close just above the number 4 , which is for a different part, you can see one of the plastic bits sticking out.i think this is the part that's fallen off on you
- Bike owned: 98 R1, 95 CB1000, 92 CB400
I wouldn't worry overly, if it's a good bike it's a good bike, no matter its history.
A quite possible explanation is that it was indeed manufactured in 2001 but not sold / registered until 2003.
- JZH
- Bike owned: RSCBRRVFVFRST
Forget that VIN. It's not a Honda VIN, it's a bunch of random numbers and letters, so it will correspond with nothing.Jazsamon wrote:Hello,
Actually, it looks like it is a New Zealand Transport Agency assigned VIN, so it will mean something in NZ, but there is no reason to believe it would necessarily accurately correspond to the actual bike's specifications. Indeed, it appears they have got the Model Year wrong. Honda export VINs start with JH2, but they may (now) have a different prefix for JDM bikes. It would probably still start with J (for Japan) and H (for Honda), though...
Looks like a nice bike!
Ciao,
