NC29 progressive linkage
				LeiWulong
Hello all, espesially NC29 owners :)
I have CB-1 with NC29 swingarm.
At the moment I am perfroming linkage upgrade: I want to install progressive linkage from NC29.
Can someone explain or make a photo of linkage (number 12 on a picture) position with a hanged out rear wheel?
I want to undestand the position of low shock linkage when swigarm is in the lowest position.
Thanks in advance.
Thanks in advance.
				LeiWulong
Re: NC29 progressive linkage
The best option for me will be to get this two dimensions with a hanged out rear wheel:
- Davez29
 - Bike owned: NC29 forever
Sorry i cant help you as i have not got those parts easily accessible.  I hope someone has their bike apart and can give you the dimensions you need.
				LeiWulong
Hi! Thanks for response anyway! :)Davez29 wrote:Sorry i cant help you as i have not got those parts easily accessible. I hope someone has their bike apart and can give you the dimensions you need.
Dimensions is a best option. At least photo will be very helpfull.
It can be a photo of shock's lower bolt position regarding to the hole in swingarm.
				LeiWulong
I have also realized that actually there is no need for 2 dimensions.
It will be enough to measure this:
The only important moment is hanged out wheel. Swingarm should take it's lowest position and shock should be fully released.
