675 forks nc35 calliper problems
I have fitted st675r forks in my rvf400 Rick Oliver wheel spacers nc35 wheel nc35 yokes but the calliper rub the discs 675 calipers help thanks
Re: 675 forks nc35 calliper problems
where are they rubbing?
They are rubbing on the inner face where the pads sit it's like the discs need to be spaced 2mm out thanks for replying
Both discs rubbing on the inner faces of both calipers? Are they captive spacers? If so did you put the lip of the spacer behind the bearing seal?
Otherwise you have the wrong spacers or somehow managed to put it together wrong.
Ye the seals are not in for test fit I have got is so they do miss but they are close wheel and spacers are in correctly spacer 25mm on left as u look from front and 20 mm on the right the Allen key shaft flush with outside of fork leg thanks. I gave the caliper a tap in just misses now
My discs measure 134mm ouside and wheel with spacers in 158mm
I have sorted it I needed 24 MM. On the left as you look from the front 20mm on right I have had the calipers milled 6mm off the mount length my bottom yoke was bent that's why I was having trouble I have rebuilt calipers because they were sticking a bit it now pretty good just got to put engine in and fit and paint fairings and we are good for the start of the season fingers crossed thanks
