Damaged fork drain bolt
rc211v
Post by rc211v »
Help!
While disassembling my front forks, I partly stripped the thread that the fork drain bolt goes into. Now, when the shock is loaded, oil seeps from that area. Any suggestions on how I can fix this? I can't afford to replace the entire fork. :cry:
Rover220
Re: Damaged fork drain bolt
Post by Rover220 »
loctite the bolt in, thatll sort it.
rc211v
Post by rc211v »
what's the best way to position the shock so I can remove the bolt without draining the fluid?
rc211v
Post by rc211v »
ok, sorted out with some plumber's teflon tape.
calirvf
Post by calirvf »
I would recommend getting that fix properly. Suspension is a vital functional part of your motorcycle and you don't want it to give out while you out riding. Then of course i dont think that will happen. :mrgreen:
