NC29 miscellaneous wire? Earth??
Posted: Wed Dec 07, 2016 9:05 am
by Gimly56
Can anyone tell me where this should go?? I'm assuming it's an Earth wire and should bolt to the frame perhaps???
Re: NC29 miscellaneous wire? Earth??
Posted: Thu Dec 08, 2016 1:06 pm
by JZH
You're right, it's definitely an earth/ground connection. It does bolt to the frame, but where exactly I can't tell you without getting to my bike (which I cannot do right now). I wouldn't think it would be long enough to fit onto too many bolts, so look for the most likely one.
Ciao,
Posted: Fri Dec 09, 2016 6:35 am
by Gimly56
JZH wrote:You're right, it's definitely an earth/ground connection. It does bolt to the frame, but where exactly I can't tell you without getting to my bike (which I cannot do right now). I wouldn't think it would be long enough to fit onto too many bolts, so look for the most likely one.
Ciao,
Awesome. Thanks for confirming that for me. Pretty sure i can find a bolt for it without too much of a problem.
Posted: Fri Dec 09, 2016 10:30 am
by tanuki
NC29?
I have had loads of 29s apart and I really dont recognize that wire.
Posted: Sat Dec 10, 2016 8:49 am
by Gimly56
tanuki wrote:NC29?
Oh no....don't you dare Tanuki??!!!
I've had quite a few 29s apart too and I didn't recognise that connection either...hence my post.
Damn you Tanuki. Now I'm worrying again!! I'll bolt it to the frame and kick it in the guts and see what becomes of it.....
Posted: Sat Dec 10, 2016 7:23 pm
by Gimly56
What's even weirder is that I have looked at the other 2 wiring looms I have spare and they have that exact same connector???
I don't remember undoing it from anywhere??!!
Posted: Sat Dec 10, 2016 10:41 pm
by dunkenb
Does it go on the frame In front of the seat ( under the tank ) ?
Posted: Sun Dec 11, 2016 9:49 am
by Gimly56
I bolted it where I figured it might go and afterwards had a look at the manual and I put it in the right place! Go figure.
I'll post a pic but it goes under the riders seat. There is a metal bracket that 3 x wiring connecters pass through. I think one is the fuel pump cut off relay? Anyway....it just bolts to the frame on that for the earth. Easy.
Posted: Fri Dec 16, 2016 4:57 pm
by JZH
I should mention that the reason why I am sure it is a ground/earth is due to its colour. Honda uses that green (also the same green with a black stripe) for grounds.
Glad you've got it sorted.
Ciao,
Posted: Fri Dec 16, 2016 9:51 pm
by Suzuki416
I have the same wire on my NC35.
Yes it is 100% an earth lead & it is bolted to the frame onto the top fairing mount just above the timing inspection cover on the RIGHT-HAND SIDE.
