Page 1 of 3
				NC35 FUEL PROBLEM
				Posted: Sat Nov 29, 2008 12:59 pm
				by rvfali
				Well pleased today, i got the bike running  :D  :D  but in order to do so, i fitted a pipe to the carbs and filled it up with fuel.
      i can't seem to get it to run off the main tank,it does not help by not knowing which way the tap should point, also could there be a vacume problem? i have put over a gallon of fresh fuel in it.
         cheers for any help alistair
				Re: NC35 FUEL PROBLEM
				Posted: Sat Nov 29, 2008 4:44 pm
				by abrmoto
				Check the vacum pipe to the fuel tap., comes frome rear right inlet and should be fitted to the fuel tap, is about a 4mm rubber pipe.
Hope this helps, if not post up and see if we casn think of out else.
Aly
				Posted: Sat Nov 29, 2008 4:56 pm
				by Psychosomatic88
				are you sure you dont want to sell me your bike?
				Posted: Sat Nov 29, 2008 5:40 pm
				by rvfali
				Psychosomatic88 wrote:are you sure you dont want to sell me your bike?
  you might not say that if you saw it
 http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... TQ:GB:1123" onclick="window.open(this.href);return false;
				Posted: Sat Nov 29, 2008 5:44 pm
				by rvfali
				abrmoto wrote:Check the vacum pipe to the fuel tap., comes frome rear right inlet and should be fitted to the fuel tap, is about a 4mm rubber pipe.
Aly
  cheers the pipe is connected to the tap, but i will check to make sure it's not split and is connected to the inlet.
  is it right in saying if you turn the tap fully to the right it's on reserve????
				Posted: Sat Nov 29, 2008 6:08 pm
				by wullvfr
				rvfali wrote:is it right in saying if you turn the tap fully to the right it's on reserve????
that is correct.........fully turned the other way(anti-clockwise)is on and in the middle is off!!!!!!
william
				Posted: Sat Nov 29, 2008 6:14 pm
				by rvfali
				wullvfr wrote:rvfali wrote:is it right in saying if you turn the tap fully to the right it's on reserve????
william
      thanks very much for that  :D
				Posted: Sun Nov 30, 2008 8:58 pm
				by rvfali
				Hi can someone tell me what the pipe is for, that goes under the fuel tank. (not the two that go on the fuel tap).
                 cheers alistair
				Posted: Sun Nov 30, 2008 9:04 pm
				by Psychosomatic88
				Where does it go to and from?
				Posted: Sun Nov 30, 2008 9:13 pm
				by rvfali
				Psychosomatic88 wrote:Where does it go to and from?
   it comes out of the bottom of the fuel tank, i can't see where it goes as my garage is soooo dark
