NC35 FUEL PROBLEM
NC35 FUEL PROBLEM
Well pleased today, i got the bike running :D :D but in order to do so, i fitted a pipe to the carbs and filled it up with fuel.
i can't seem to get it to run off the main tank,it does not help by not knowing which way the tap should point, also could there be a vacume problem? i have put over a gallon of fresh fuel in it.
cheers for any help alistair
- abrmoto
Re: NC35 FUEL PROBLEM
Check the vacum pipe to the fuel tap., comes frome rear right inlet and should be fitted to the fuel tap, is about a 4mm rubber pipe.
Hope this helps, if not post up and see if we casn think of out else.
Aly
Aly
- Psychosomatic88
are you sure you dont want to sell me your bike?
Going on the internet is like owning a gun... Just point, click, then shit your pants waiting for the Police to turn up.
you might not say that if you saw itPsychosomatic88 wrote:are you sure you dont want to sell me your bike?![]()
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... TQ:GB:1123" onclick="window.open(this.href);return false;
cheers the pipe is connected to the tap, but i will check to make sure it's not split and is connected to the inlet.abrmoto wrote:Check the vacum pipe to the fuel tap., comes frome rear right inlet and should be fitted to the fuel tap, is about a 4mm rubber pipe.
Aly
is it right in saying if you turn the tap fully to the right it's on reserve????
- Bike owned: zx9r c1
that is correct.........fully turned the other way(anti-clockwise)is on and in the middle is off!!!!!!rvfali wrote:is it right in saying if you turn the tap fully to the right it's on reserve????
william
thanks very much for that :Dwullvfr wrote:that is correct.........fully turned the other way(anti-clockwise)is on and in the middle is off!!!!!!rvfali wrote:is it right in saying if you turn the tap fully to the right it's on reserve????
william
Hi can someone tell me what the pipe is for, that goes under the fuel tank. (not the two that go on the fuel tap).
cheers alistair
cheers alistair
- Psychosomatic88
Where does it go to and from?
Psychosomatic88 wrote:Where does it go to and from?
it comes out of the bottom of the fuel tank, i can't see where it goes as my garage is soooo dark
