NC35 SPARK PLUGS
rvfali
NC35 SPARK PLUGS
Post by rvfali »
HI as i've got half my plugs out i throught i would change them :D The ones in the bike are NGK ER9EH, is that correct and any idea what the gap should be, how easy is it to get to the front ones?
cheers for any help alistair
Psychosomatic88
Re: NC35 SPARK PLUGS
Post by Psychosomatic88 »
Yes there correct, or er10eh for race use I think. Unsure of plug gap. The front ar eeasy to get too, but you will find it easier to drop the front rad.
Un bolt if from the left side, the slide it off its support and voila :D
A haynes manual will tell you the gaps if you you need it aswell as other technical bits
Going on the internet is like owning a gun... Just point, click, then shit your pants waiting for the Police to turn up.
pretty sure it is 0.6 - 0.7 for the gaps.
prepare for skinned knuckles on the back of the top rad when whipping them out..
royster81
Post by royster81 »
CMSMJ1 wrote:pretty sure it is 0.6 - 0.7 for the gaps.
0.7-0.8 i thought but nevermind,or you can take the top rad off and do the coolant at the same time,better still ,pop the rads on some water while your doing the plugs to help clear them,then with the new coolant the bike will love you for it ....
let's go for a 0.7 then ;)
good idea about the rads..mine are off right now but just hanging up..lol
royster81
Post by royster81 »
CMSMJ1 wrote:let's go for a 0.7 then ;) agreed
good idea about the rads..mine are off right now but just hanging up...cos you got some fancy pants rads to refit...
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
the correct gap is 0.6-0.7mm as cmsmj1 says........
er10eh are usually fitted for extended high speed use(race)but i have heard of people using the er10eh in the rear two cylinders as they can get hotter.....supposedly!!!!!!
william
rvfali
Post by rvfali »
Thanks very much for all your advice :D i'm going to try and start it tomorrow :roll:
cheers alistair
