Normal Running Direction?
				Hubbskiboy
- Bike owned: GK76A 1993 and 1990
Can anyone tell me the normal running direction for a GK76A?
i.e. when I've got the right side clutch cover off and I'm looking straight at the flywheel, which way should it turn when running.
I'm asking because I want to keep the pistons from seizing over the winter and I want to put a few drops of oil in each cylinder and turn the engine over manually with a wrench.
Also, would it damage the engine if I turned it the wrong way for a quarter of a turn?
I hope I haven't buggered it!
I'm guessing clockwise is the correct way, but would appreciate any feedback.
The manual isn't much help as all it states when checking the valve clearance is "rotate in the normal running direction".
That's useful isn't it!!!!!!!!!!
				dobbslc
Re: Normal Running Direction?
Pretty sure from the right hand side it's clockwise. Put it in 3rd gear and turn the back wheel forwards watch the engine flywheel.  Turning it backwards is a bad idea as the camchain can jump a tooth as it loosens off.
You're more likely to get trouble with the carbs, make sure you run them dry before laying it up.
				Hubbskiboy
Hi dobbslc.
Thanks for the info.
It's going to have a top end rebuild anyway before I run it again next year, so the cam chain jumping a tooth shouldn't be a problem.
It turned fine when I was turning it over slowly clockwise with a socket wrench as you have confirmed.
I can't use the back wheel in 3rd gear method as it's pretty much the engine in the frame only at the moment.
No gear shifter lever, no rear wheel!!
If I need to check 100% the flywheel direction I'll take the clutch access 'bung' off my other GK76 and turn it over.
I'm surprised that there is absolutely zero info on the internet about this.
