NC23 Aero Service Manual Required for valve adj
SteveBurden
- One Hit Wonder
Hi. I'm looking for a manual so I can do a valve adjustment. Stripped it down taken the valve cover off. Worked out the sequence to check. Some valves I can just about slide a 0.1mm feeler under. Was also suprised to find old style tappet adjusters. Any help would be appreciated.
fastrob691
Re: NC23 Aero Service Manual Required for valve adj
I have a manual at home, i'll get the specs after work and give you the measurements.
04colyZQ8
I'd love a manual for a areo!
I have a 86, interested in valve guide clearances, engine specs
Valve guide size, valve spring free length etc..
