Nc35 trouble starting and idleing
- Bike owned: NC35
Hi all
Having some issues with my NC35
When the bike has been standing for a night of a few days i have a massive mission to get her started and if i do get her going she battles to idle and rev up.
Ive run out of options please help
MAV
Sent from my SM-N910F using Tapatalk
MAV
- Bike owned: VFR400
Re: Nc35 trouble starting and idleing
Starts easy once warm?
- Bike owned: NC30 type1 MC18 red MC18 blue
Carbs balanced, valves clearances checked?
- Bike owned: NC35
Most of the time yes...valve and carbies are fine when she is still a bit coldish when you pop the the throttle revs drop and she dies
They all need some warmup from cold.
Choke and vacuum tap working correctly.
Personally found that converting vacuum fuel tap to fully manual improved the startup if the bike had not been used for a few day. Think fuel evaporation and slow float bowl refill, as consequence of limited vacuum during cranking, may have been the issue.
- Bike owned: NC35
Mag your manual tap from what bike is that or how did you convert it
Used the guide in the HRC TT formula 3 setup doc from this site library. Rearranged the tap internals using the spring to keep diaphragm open and plugged the vacuum hose from the intake. Apologies for the lack of clarity, been a while since I did it.
- Bike owned: NC35
Awesome thanx
- Bike owned: NC35
Magg can you send me link please
