My Nc24 dies when driven fast for long?
Posted: Tue May 31, 2016 6:22 pm
by ruankoekemoer001
Good evening everyone. I am stuck with a big issue. I have a 1989 vfr nc24 and it dies on a freeway of a long road. Then as soon as i come to a stop. She starts up again after a swing or 2 but sometimes i have to sit and wait. Everything is fine(oil, sparkplugs ect) Can anyone mabey tell me what the problem is and the best possible solution to fixing it. Thanks Ruan
Re: My Nc24 dies when driven fast for long?
Posted: Tue May 31, 2016 9:21 pm
by jim157
The vacuum pipe on your fuel tap might need replacing or the fuel tank breather might be blocked.
Posted: Wed Jun 01, 2016 7:56 am
by ruankoekemoer001
Thanks jim i will check it out
Posted: Wed Jun 01, 2016 1:56 pm
by manicguitarist
Yup, sounds like vacuum pipe to the fuel tap. If it is the original it will almost certainly be perishing.
M
Posted: Wed Jun 01, 2016 2:31 pm
by RichardJ
Diaphragm split in the fuel tap. My nc24 had the exact same symptoms when I bought it in 1992!
Posted: Wed Jun 01, 2016 3:44 pm
by ruankoekemoer001
Thanks everybody relly appreciate it
Posted: Thu Jun 02, 2016 4:27 pm
as above i think the others have already nailed it.
common failure is old vaccum pipe going hard and brittle.
pull the vaccum hose and stretch it a little, itll probably break off near the engine block where it conncets.
fuel tap diaphram can split too but the vacuumn line is more common
