My Nc24 dies when driven fast for long?
Good evening everyone. I am stuck with a big issue. I have a 1989 vfr nc24 and it dies on a freeway of a long road. Then as soon as i come to a stop. She starts up again after a swing or 2 but sometimes i have to sit and wait. Everything is fine(oil, sparkplugs ect) Can anyone mabey tell me what the problem is and the best possible solution to fixing it. Thanks Ruan
- jim157
Re: My Nc24 dies when driven fast for long?
The vacuum pipe on your fuel tap might need replacing or the fuel tank breather might be blocked.
AUTOEXEC.TWAT
Thanks jim i will check it out
- Bike owned: RVF400 (NC35)
Yup, sounds like vacuum pipe to the fuel tap. If it is the original it will almost certainly be perishing.
M
M
- Bike owned: NC30 type1 MC18 red MC18 blue
Diaphragm split in the fuel tap. My nc24 had the exact same symptoms when I bought it in 1992!
Thanks everybody relly appreciate it
as above i think the others have already nailed it.
common failure is old vaccum pipe going hard and brittle.
pull the vaccum hose and stretch it a little, itll probably break off near the engine block where it conncets.
fuel tap diaphram can split too but the vacuumn line is more common
