CBR400RR NC23 FORK BUSHES
sleepyboy
- Bike owned: Too many to list
- Davez29
- Bike owned: NC29 forever
Re: CBR400RR NC23 FORK BUSHES
Interesting, do you know the part numbers these replace? as i was looking at buying some for my 29 and the bushes alone are over £40 at DSilvers.
sleepyboy
Hi Dave the parts numbers are the same,51414-MN5-003 and 51415-MM8-003 , you can check this at
http://www.bike-parts-honda.com/microfi ... piece.html
But certainly All Balls is the cheapest Ive found for all the parts you get with them, just need to get the oil seals and dust covers but I think Pyramid do a good price on them
- Davez29
Well if thats the part numbers they do look to be the same as my bike, worth a go i guess. Post back with your findings when you fit them to see if theres any problems.
The reason i say that is that a while ago i bought a All Balls rear wheel bearing kit, marked to fit my bike and the bearings were all oversize and i had to return the kit. The store didnt believe me until i showed them the data for the oem bearings. On the flip side i use All Balls head bearings, no problems at all.
sleepyboy
Hi Dave, have split my forks, got the old bushes out, compared them first ,same size, put them on the stanchion , and slid them into the sleeve ,perfect , so will be sending the stanchions away for chroming
CB1pod70
Wemoto list fork bushes for the CB-1 http://www.wemoto.com/bikes/honda/cb-1_ ... ket/89-90/
As far as I can tell (same part numbers on CMSNL) they are the same for both bikes. I've used them on a CB-1 and they work fine.
