Hrc style Airtray for dyno run ??
MARSHnc30
Post by MARSHnc30 »
Hi guys getting to the point where my race bike is nearly ready to put on a dyno but quick question do I need the hrc copy Airtray on for the dyno run or can I get it done without as it will make it easier to play around with the jetting if it off !!
hunter
Re: Hrc style Airtray for dyno run ??
Post by hunter »
Without it the airflow to the carbs will be different.
So you may well need to get it done twice.
GeeTee
Bike owned: NC30 & GSXR750K4
Post by GeeTee »
I have a fiberglass HRC tray for sale if you need one
I reckon it does more of a job shielding the carbs from the heat than any kind of ram air bollocks.
dyno run without it will be no worries I reckon
richyrd5
Regular Member
Post by richyrd5 »
:plus:
RVF
Post by RVF »
It should be fine to set it up without it fitted as long as its just the tray. We set the RC30's up the same to make it easier.
