Can someone measure an nc30 piston pin please?
Yakama
Post by Yakama »
I'm wanting to know if they are the same length and width as those used in the rvf400 and later cbr400 Pistons. Thanks
lukemillar
Re: Can someone measure an nc30 piston pin please?
Post by lukemillar »
I can when I get home. When you say width and length - do you mean diameter and height?
Height/skirt is definitely different but the bore should be the same:
Yakama
Post by Yakama »
Sorry Its the actual pin not the hole, like part 3 in this diagram:
http://www.cmsnl.com/honda-vfr400r3-199 ... ml#results
lukemillar
ah yep - will do tomorrow morning
Yakama
Post by Yakama »
Thanks very much
lukemillar
Height= 42.82mm
Dia= 13.98mm
Will post vernier pics later
Yakama
Post by Yakama »
Ah ok so that's a few mil longer than the nc29 pin, I was hoping it would be a fewmil shorter.
Reason is I got these moriwaki Pistons in with some parts a while back, I was told they are for the cbx400 but they definitely aren't! I have the parts manual and they are the wrong part no. I think they are either nc30 or cbr400 but they have slightly deeper valve pockets and the pin height is different
In comparison with an nc30 piston
Yakama
Post by Yakama »
They didn't come with piston pins, so I wonder if I could get the nc29 ones shortened to fit??
lukemillar
Yep - the NC30 pin is longer than the NC35
Not a good pic for measurements but you can see the two here:
L- NC35, R- NC30
Should be a easy thing to machine though
Yakama
Post by Yakama »
Mystery solved. It seems these are moriwaki f3 race pistons for the nc21
