Starting problem
samurai blade
Starting problem
Hi All !
I had to sort a oil leak from the crankshaft cover - nc30.
Got a second cover which was welded and ground flat .
During fitment - stà rter idler gear came out with shaft .Pushed båck ,had to move starter clutch anti~clockwise.No marking's for starter clutch alignment -visible.Crankshaft marks line up !
Please help with any info !
Thank's
Re: Starting problem
What does it do or not do?
Does it turn over? does the starter itself turn over?
NC35!
The starter clutch locates on the crankshaft with the help of a wide spline type arrangement - in other words there is no way you can "unalign" this part. The idle/reduction gear simply "joins" the starter motor shaft to the starter clutch, there are no timing concerns here at all.
If your engine is not starting, it's not as a result of the starter gear dislocating.
I know, my terminology sucks!
samurai blade
Hello !
START UP
Slow crank over - like battery is dying -multimeter shows that battery is above 12 volts .
Check list - choke /no throttle ,kill switch,vacuum pipe,air ,fuel,spark,starter brushes -ok ,extra clean earth's .
What is the limit to skium/ground crankshaft cover ?
mm = ?
Thank's
START UP
mm = ?
Thank's
Battery seems a little low
The voltage in your charegd battery should be 14V or so..if it is only just 12 then when you fire it up it will drop below 10 and turn sowly.
I would get a jump lead setup from your car or get another battery to start with.
wullvfr
- Bike owned: zx9r c1
at what point is the battery showing just above 12volts?
when the bike is started and running the volts should be 13.5-15 volts@5000rpm!!!!
william
william
NC35!
William,
There's a good guide to battery checking here:
http://www.hondarvf.com/workshop/my-battery-any-good%3F" onclick="window.open(this.href);return false;
wullvfr
NC35! wrote:William,
i dont understand......im not the one with the starting problem!!!!!!
i asked at what point was his battery showing just above 12volts and gave a little advice on what the readings should be.which is 13.5-15volts @5000rpm
william
NC35!
D'oh! Stupid me - I mis-read your post. Silly me for trying to be helpful!wullvfr wrote:NC35! wrote:William,
william
wullvfr
no harm doneNC35! wrote:D'oh! Stupid me - I mis-read your post. Silly me for trying to be helpful!
william
