600 conversion 'dancing' tachometer.
clarkee
- Bike owned: fzr400
Hi, sure I've seen some information on fixing this, can anyone point me in the right direction?
Brian
Brian
hunter
Re: 600 conversion 'dancing' tachometer.
Are the fuel sender wires connected.
As this is usually the cause.
If only there was a thread to help you maybe at the top of the Workshop forum ???
viewtopic.php?f=37&t=4143
1966baz
Thanks Evil chicken. I've just read through the thread carefully as my 3tj /thundercat hybrid has the old dancing tacho to 8 000 and back. Always thought it was the fuel level sender but been through all that. It seems it might be the throttle position sensor. I will conquer this one, just spread myself too thin working on a TZR 250 and building a 350ypvs hybrid and the 400 RRSP. Probably a bit cracked having too many little yams but they keep me sane.
Fit the FZR600R Foxeye cdi to cure it
1966baz
That would presumably plug straight into my Thundercat loom and all's sorted. Thanks again for all your input into this forum.
It should just plug in. There's no TPS on the 600r
1966baz
Ok, thanks for for that, I'll look on the bay for one.
clarkee
Thanks I'll give it a go
1966baz
Just put an Fzr 600 CDI in and hurray , the tacho now works. Thanks again Evilchicken.
