Charging problem
demerdzhiev
- Bike owned: NC21
Charging problem
When at idle the voltage is 13.2 and when it goes to 5k it is already 12.5 Instead of going up the voltage goes down. Any suggestions
here's a short video:
https://www.youtube.com/watch?v=moke_IOGebY
- vfrman
- Bike owned: NC30, 1098s
Re: Charging problem
Regulator/Rectifier
- Bike owned: VFR400
Connect rect/reg output directly to battery terminals.
demerdzhiev
- Bike owned: NC21
Will try that magg, if it doesnt help i will change the rect/reg
edit: which are the + and - wires on the rect/reg :D
Usually on the loom side green is -ve and red/white +ve.
fatpete
- Bike owned: NC35 (RIP), CBR900RR, NC 30
I had the same issue last year, swapped the rec/reg and back up to 14v @5000 rpm, so that would be my first thought.
manicguitarist
- Bike owned: RVF400 (NC35)
Not reg/rec.
Well, it still could be - but I have seen this before (and on mine). It is down to the impedance in the wiring loom. Greater voltage at the reg/rec causes higher current through the wiring loom and a bigger voltage drop before it gets to the battery.
Solution is to perform the mod where you wire the reg/rec direct to the battery (via a fuse obv!). I did this and all is peachy. Took about 20mins I seem to recall. Most of which was getting the rear bodywork off. I'll try to find the thread on here for you.
manicguitarist
manicguitarist
Also see here viewtopic.php?f=24&t=49827
demerdzhiev
- Bike owned: NC21
everything is clear except the part with the fuse, i am an electricity cripple so pls help with the fuse :D
