thread inserts question
Posted: Mon Mar 28, 2016 1:54 pm
by Dynamohum
I am currently working my way round a tatty rvf i just bought uncovered some horrendous bodges all rectifiable however having removed rads found lower front left engine mount had a 150 mm length of threaded rod in place of the bolt and spacer
Tried a m10 1.25 bolt but thread has gone would apreciate any recommendations for a thread repair in situ if possible or if needs must will drop motor out to enable repair.
Re: thread inserts question
Posted: Mon Mar 28, 2016 2:36 pm
by hunter
Posted: Mon Mar 28, 2016 6:24 pm
by Dynamohum
Thanks hunter that looks a good system but a bit expensive for a one off job though.
Posted: Mon Mar 28, 2016 7:00 pm
by hunter
You can buy the inserts separately,
You don't need all the tools,
A drill bit an the correct thread tap.
Posted: Mon Mar 28, 2016 9:10 pm
by Dynamohum
There's a wurth trade counter not far from me will pop in on way to work and see if they can supply what's required . it certainly looks a better solution than the old helicoil method thanks again.
Posted: Mon Mar 28, 2016 10:43 pm
by hunter
I should have said that you could use a nut and bolt to turn it in.
Posted: Mon Mar 28, 2016 11:47 pm
by RickOliver
+1 on that - Wurth Time Sert is a much better repair system than the old Helicoil types
Rick
Posted: Tue Mar 29, 2016 11:47 am
RickOliver wrote:+1 on that - Wurth Time Sert is a much better repair system than the old Helicoil types
Rick
indeed! +1
used one on my fireblade (used two actually as i drilled the wrong hole first
