thread inserts question
Dynamohum
Post by Dynamohum »
I am currently working my way round a tatty rvf i just bought uncovered some horrendous bodges all rectifiable however having removed rads found lower front left engine mount had a 150 mm length of threaded rod in place of the bolt and spacer :roll:
Tried a m10 1.25 bolt but thread has gone would apreciate any recommendations for a thread repair in situ if possible or if needs must will drop motor out to enable repair.
hunter
Re: thread inserts question
Post by hunter »
Time sert not cheap but more than effective.
https://www.youtube.com/watch?v=z5Pz66P ... 5M57xNZjjA
Dynamohum
Post by Dynamohum »
Thanks hunter that looks a good system but a bit expensive for a one off job though.
hunter
Post by hunter »
You can buy the inserts separately,
You don't need all the tools,
A drill bit an the correct thread tap.
Dynamohum
Post by Dynamohum »
There's a wurth trade counter not far from me will pop in on way to work and see if they can supply what's required . it certainly looks a better solution than the old helicoil method thanks again.
hunter
Post by hunter »
I should have said that you could use a nut and bolt to turn it in.
RickOliver
Post by RickOliver »
+1 on that - Wurth Time Sert is a much better repair system than the old Helicoil types
Rick
RickOliver wrote:+1 on that - Wurth Time Sert is a much better repair system than the old Helicoil types
Rick
indeed! +1
used one on my fireblade (used two actually as i drilled the wrong hole first :P)
