carbs will not balance!!!!!!!!!!!
Damien420
Post by Damien420 »
Hi,
When bike was warm idle was a bit rough so decided to buy a carbtune and balance them. First i stripped them and ultrasonic cleaned them. New seal kit from rick new plugs and even checked valve clearances, which were all ok. Built carbs up and set them on the bench like i have seen mentioned by setting marster carb with idel scew so the first small hole is just visible then worked my way arround them all. Put them on the bike and hey presto bike fired up straight away and once warm idle was better, and better throttle responce. Looked at carbtune balancer and all carbs were close except marster carb (no 2) it was a lot lower than the rest so I balanced that to no 4, not too much fuss but engine speed went up and back two carbs went right up on balancer then engine speed went up even more and then no matter what i adjust it gets worse and worse untill engine speeds up that much i have to turn it off. I have taken them off 4 times now to reset on bench but same problem every time. Any one any ideas? Am i doing something really stupid? Way i feel it will be free to a good home cos im sick to back teath :x
sleepyboy
Bike owned: Too many to list
Re: carbs will not balance!!!!!!!!!!!
Post by sleepyboy »
Hi matey , in your description you said you balanced master carb no2 to 4, did you mean 4 to 2?
viewtopic.php?f=24&t=40719
Check site out its there ;)
Damien420
Post by Damien420 »
Hi mate,
Sorry yes i mean 4 to 2
Damien420
Post by Damien420 »
Just looked at that link cheers, was using that yesterday but it just will not balance!?
sleepyboy
Post by sleepyboy »
Hi did you use the bikes tank propped up or an auxiliary tank.
Damien420
Post by Damien420 »
Used the bikes tank back on bike in corret place and sucked on tap vacume hose then bent it over and peged it.
sleepyboy
Post by sleepyboy »
did you start with pilot screws set at the correct turns out after you had cleaned the carbs, and have you got the idle set too high only need about 1500 to 1800, check that , when the bike revs too hard just try winding off the idle speed first and take it from there
Damien420
Post by Damien420 »
They were all 2 turns out so just put them back to same setting when i put them back in.
sleepyboy
Post by sleepyboy »
sorry matey just edited my last post
sleepyboy
Post by sleepyboy »
And don't get frustrated matey , its all part of the game and you will succeed and it will be all your own endeavour , and a feeling of achievement
