CARBS AND GEARING
CARBS AND GEARING
Hi All,
Just got my third SF which is a 98 version R. My previous 2 were 1992 project big ones. Sprockets and chain needed replacing,so i bought a kit which had a 42 rear sprok. This made it struggle slightly on steep hills.Checking around i found it should have a 45 rear,which i have fitted and alls well. Question is, whats changed between the two models to need different gearing?
Second. how do i get to the inner two pilot screws to adjust mixture? Or is there a certain tool i can buy?
thanks chaps, JEZ
thanks chaps, JEZ
- Bike owned: 1CB400 SF 1 VFR800 1 Moto Guzz
Re: CARBS AND GEARING
Right angled screwdrivers are available on Ebay
Thanks for that,Jack. Got one ordered.Superjack44 wrote:Right angled screwdrivers are available on Ebay
Hi, I was told that rear sprocket for mine (92 model, was 44, had a 45 on rear and 15 on front) wore out chain quicker...
Therer plenty sprockets on the market and chains ive upgrade mine to 47 rear 18 front nd ej heavy duty gold chain bike goes like stink bro hills are a piece of cake nd top end is still there
Sent from my LG-V490 using Tapatalk
Theres a an actual math to calculating thw sprocket size depending on what you want higher top end or acceleration and the type of driving you do mine is set up for the roads i drive on a daily
- Bike owned: 1994 CB400SF, 2008 CBR600RR
I'm running 16-39 gearing. Carbs are at 2 turns from seated on the mixtures. Does fail a little on steep hills but nothing a gear down or 2 can't fix. Makes twisties fun as don't really need to get out of first or 2nd (110 on limiter in 2nd.)
