nc30 clutch cable routing
Is there a schematic for cable routing?I've tried the search but nothing..i do remember seeing one?does it go up the left side(same as speedo)then through yoke..or does it go across engine and out up the right?also I ve 2 different length cables one being much longer...the red one which came on bike is shorter and comes up the left and out to lever mount
- Bike owned: NC 30, TZR 250
Re: nc30 clutch cable routing
There is one in the honda workshop manual which I can scan or email you tomorrow. I also think the manual is available on carlsalter.com as I have the download on my pc .
The clutch cable passes cross the steering stem and through the nosecone mount bracket on the left hand side of the bike as viewed when sat on the bike and down to the clutch mechanism . I have been supplied different pattern lenght cables on occassion but always revert back to genuine .
Cheers for that...so does it come out from the right(when sat on bike)then through headlight bracket(then through top yoke bracket although I don't have this as I have tyga yokes)or is it different...
the manual is also on this website, in the docuemtns library (link at top of page)dirty30-2008 wrote:There is one in the honda workshop manual which I can scan or email you tomorrow. I also think the manual is available on carlsalter.com as I have the download on my pc .
thanks neo,i did look but didnt see it!
