Will a NC30 front cowl fit a NC35
bjhanss
Hello out there
Due to problems with the norwegian road authorities (they require EU marking on headlights ), I am looking into purchasing a NC30 German or French front cowl and lights. Can anybody give some feedback if this is a feasible swap, and if the NC30 headlight and tacho bracket will fit ?
Bjoern
Bjoern
Re: Will a NC30 front cowl fit a NC35
you need all brackets and some will, then I reckon you may get it on - the brackets and mounts are not the same.
How about RC45 lights?
probably be made to fit, but be surpised if any of it is bolt-on.
depends on how much you have to spend.. for the cost of it you could just get some generic eu marked round lights, make up a brakcet to hold them make some fibreglass surround to fit them into the fairing.
- JZH
- Bike owned: RSCBRRVFVFRST
Sorry to hear this. The RVF headlight is unique, so there won't be any E-marked versions that fit the RVF fairing. Replacing the fairing with an NC30 one would spoil one of the RVF's best features...
How many testing stations are there in Norway?
Ciao,
Ciao,
bjhanss
Hello JZH-
I have ditched the NC30 fairing idea, as I found two DOT-marked headlights which are accepteble. I will make a bracket that fits the original fairing, then present the bike once more.
Bjoern
Bjoern
- JZH
Good luck. You can aways switch it back after...
Ciao,
Ciao,
