Page 1 of 2
SF Forks Questions
Posted: Fri Nov 21, 2008 11:07 am
by Ensie 27
Do all Superfours have the same forks
What size are they
Does anyone have a top yoke that they could take dimensions off please
TIA
Re: SF Forks Questions
Posted: Fri Nov 21, 2008 8:22 pm
by alexibrow
I believe that they're all the same, and they're 41mm in diameter (I'm sure someone will correct me if I'm wrong!)
Annoyingly, the guy who bought my Version R just collected the spare forks this evening, so I can't measure anything for you...
Posted: Sun Nov 23, 2008 3:55 pm
by Ensie 27
Posted: Wed Dec 10, 2008 8:47 am
by chris_r
Sorry to hijack, but CBR600s of the same year have very similar forks, does anyone know if they're a straight swap as SF forks are like hens teeth around these parts.
Posted: Wed Dec 10, 2008 2:14 pm
by Mansie
You need to look for the part number and start your search from there.
For example, my CB400 NC36 1998 has its own 41 mm diameter stancheons:
p/n 51410-MBE-003
The fork bottom part numbers are:
51420-MW3-E11 (R)
51520-MBE-003 (L)
Middle code MBE means: specially intruduced part number for this model.
If you search on the CMSNL website for the fork bush slider 51415-KCR-003 you can see it is used in a lot of other models such as the cb1, the cb600 range, the cb750 seven fifty, the CBF600 etc, all 41mm forks.
The next question is: are the forks equally spaced on all models? You need to measure the distances on the yoke that you have and compare with the one on the CB600.
Posted: Wed Dec 10, 2008 2:50 pm
by Ensie 27
chris_r wrote:Sorry to hijack, but CBR600s of the same year have very similar forks, does anyone know if they're a straight swap as SF forks are like hens teeth around these parts.
Whats wrong with the forks you have? Bent? pitted?
Posted: Wed Dec 10, 2008 5:33 pm
by chris_r
Thanks guys.
There's some pitting, but not a huge amount. I've changed the seals three times between the two forks and ones's just gone again. It's really annoying. As far as I know, I'm doing it by the book, but it doesn't seem to be doing me any good.
Just investigating possibilities at the moment.
Posted: Wed Dec 10, 2008 7:33 pm
by amorti
Have you changed the bushes yet? If they are overly worn, the seals will be wearing in a rocking as well as reciprocating motion, so will die quicker.
Posted: Wed Dec 10, 2008 8:55 pm
by Ensie 27
Also, the pitting won't help, if the rust spots aren't too bad, you can rub them down and fill with superglue, (believe it or not). Something else - the seal can get damaged when you slide it onto the fork, try placing it over some cling film first and lubricate it with some fork oil. Are you using good qualitty seals?
No idea of quality, but there's someone selling new Stantions on yahoo Japan for about £70:-
http://translate.google.co.uk/translate ... n&ie=UTF-8" onclick="window.open(this.href);return false;
Used forks go for about £30 but obviously would cost more to post.
Posted: Sat Dec 13, 2008 11:32 am
by chris_r
Thanks again guys.
I have new oil seals, dust seals and fork tube bushes waiting for me to collect. Hopefully, I'll get both forks done today.
