NC31 Fork won't split
Hi all,
Doing what I thought would be a basic fork seal replacement has turned into a nightmare, I've been unable to split the fork. I've taken the dust seal off, circlip out, oil out, damping rod bolt out and using the slide hammer method I can't get them apart.
I've tried heating them up but they still won't budge.
Any ideas ?
Any ideas ?
- Bike owned: HondaCB400sf version R
Re: NC31 Fork won't split
Hello. I would like to ask you, if you have remove the first allen bolt that shows up in this video.
https://www.youtube.com/watch?v=5A0p2OH6FmI
If not you should watch out. In my case this is allen bolt did not come as easy as it shows up in the video. I managed to open this bolt using Air wrenches.
I had the same problem as there is locktight on it...I think in the end I put them back together and needed some compression on the fork with an impact driver
Yep removed all the bits and pieces, now just on the part where I need to use the slide hammer technique.
The problem is, everything I slide hammer the fork gets stuck and I need to give the fork leg a gentle tap with a hammer in order to try the slide hammer technique again.
- royster81
I've had this happen before, I think the bush on the Stantion is getting stuck under the bush on the fork lower.
Hi mate.
It seems.like your bushes are riding eachother an the more you pull the more its going to get stuck. Try gently moving it to the edge till it barely touches then one strong pull. Might b better if someone helps you. If that doesnt work u might as well just pull it hard nd u might as well buy new bushes coz they probably cant be used again now. Dw they are cheapish.
Im currently ttying to cahbge the seals too but that alankey screw at the bottom is giving me a hard time. The one of the other side came off ok, but this one wont bulge. Dont have compressor or air tools.... any ideas ?
Sent from my GT-I9300 using Tapatalk
