4jh carbs
4jh carbs
Before I go and buy a set of 4jh carbs for another hybrid I have a set of 4he a set of 3 en and a set of 3uu carbs, Im pretty sure the UU ones are no good but would any of the others work on the foxeye engine? If not if anyone has use for them give me a shout
Re: 4jh carbs
3he will probably work ... but ... if you by some 4jh or 4tv they'll be close to the right mixture setting. That in turn will be useful when you try to start the engine the first time. If the engine doesn't run you won't know what to change.
