A question of model
Chalky
A question of model
Post by Chalky »
http://www.suzukicycles.org/photos/GSX- ... n2_790.jpg" onclick="window.open(this.href);return false;
I can't read Jap but would they have carried the graphics on from 1991, as I'm led to believe mine is a 1992?
Bike in question is bottom left with the zig zag stripe.
Apologies if this is a daft question :scare:
Chalky
Re: A question of model
Post by Chalky »
1991 Suzuki year code: M, GSX-R400RM, GSX400RFM, GSX400RFNM
Mine is the M :s
Quote from:
http://www.suzukicycles.org/GSX-R-series/GSX-R400.shtml" onclick="window.open(this.href);return false;
brentz250
Post by brentz250 »
Hi
Just bought a gsxr 400, and was looking for a bit of help identifying the model, the links above have been really helpfull but mine seems a little different. Mine looks to be a 1991 SPII, the paintwork is exactly the same but it does not have a black number board on the rear seat, it has a white number board.
The frame number is GK76R 104210
If it is the SP what is the difference, from the spec sheet on the above links it seems as though it is only the wheelbase.
Any help anyone can give would be greatfully received
bren
TeamGSXR
Post by TeamGSXR »
From the old forum courtesy of sharman72
Model Starting Frame Number
GSXR400 J GK73A-100048
GSXR400 FJ (SP) GK73A-100058
GSXR400 RAK GK73A-106574
GSXR400 RFAK (SP) GK73A-107598
GSXR400 RFK (SP) GK73A-107598
GSXR400 RL GK76A-100001
GSXR400 RFL (SP) GK76A-100056
GSXR400 RFNL (SP) GK76A-101457
GSXR400 RM GK76A-103110
GSXR400 RFM (SP) GK76A-103115
GSXR400 RFNM (SP) GK76A-103120
GSXR400 RN GK76A-105595
GSXR400 RK GK76A-106574
GSXR400 RP GK76A-107460
GSXR400 RS GK76A-109076
GSXR400 RSK (SP) GK76A-110004
brentz250
Post by brentz250 »
Hi
thanks for the response, however i cant seem to find my chassis number, mine is GK76R.
I ve attached a pic of it - i think -, any idea what the diff is between a standard and a sp
cheers
bren
TeamGSXR
Post by TeamGSXR »
looking at "The frame number is GK76R 104210" falls into;
I have a GK76a SP on a G plate (1990).
From what I can tell it has a closer ratio gearbox, TPS (throtle position sensor), larger carbs, rear shock is adjustable and a different single plug CDI.
http://www.400greybike.cc/newforum/view ... =53&t=3365" onclick="window.open(this.href);return false;
Cheers,
J
timoth123
Post by timoth123 »
TeamGSXR wrote:looking at "The frame number is GK76R 104210" falls into;
Cheers,
J
as well as fully adjustable front forks, not just preload like the standard models.
gixxerpaul
Post by gixxerpaul »
if its an sp it should have a trottle sensor on the left hand side of the carbs a black unit with a wire going to a white plug
mj43
One Hit Wonder
Post by mj43 »
Which models had RWUP forks?
After a set of RWUP SP forks
Tiked12345
Post by Tiked12345 »
Could anybody please help me identify my gsxr 400 can't seem to find much on these from the internet was told it's a sp2 but a don't believe it is does have the throttle sensor on it frame number is gk76a106447. Engine number k709106491 thanks
